i want to run four dc lvl4 15s off a dc 5k. i have one mech man 260 amp alt.1 run of 0/2 welding wire and two kinetik 2400. would this amp be to much for theses subs? 2 or 3 runs of 0/2 welding wire? and how many more kinetiks would i need to run?
Whip:2004 Ford Expedition
Headuint:Pioneer AVH-P4200DVD
Alt:MechMan 270 Amp
Big 3: Yes
Rear batts:2x Kinetik HC2400
Power Wire:carolprene 0/2 welding wire
Volt Meter:X Scorpion
Front stage:Kicker KS6502
Rear stage:Polk audio 6x8s
High Amp:Boston acoustic GT-4100
Sub stage:Audio Que HDC3 18s Copper Coils D2
Low Amp:Audiopipe AP30001D
Box:6ft3 96in2 34hz
146.8 dbs @ 35hz Sealed up
The 5k will not be too much, I would look into 4 more batteries if you plan on hard daily use. Just my view, let the experts decide. GL :drink40:
06 GP GXP
Google Nexus 7 16gb
Rockford Fosgate 3SIXTY.3
*Electrical*
DC Power 320a HP
2 - Juicebox Bananas g31
Stinger SPP2250 rear
Kinetik HC1800 side of wall
Optima Red Top front
Monster Cable 1/0, 2 runs to rear
Monster Cable 1/0 Big 3
2-Rockford Fosgate T1652S's
Rockford Fosgate T400-4
Rockford Fosgate T40001bd (4693rms @1ohm)
4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's
15.2 cubes net tuned @34hz! Walled off
DBdrag official 151.6db @46hz
GXP Build log!:GP GXP Walled
Quality is the sign of a true enthusiast!
Refs: Link to leave more: http://www.stevemead...91#entry1603091
Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0)
Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
I don't think your electrical will support above 14 volts steadily and your question is going to depend on many factors. My advice is don't do it. You plan on feeding two 1,000rms subs 5,000. If you have to ask, you probably don't have the experience with running subs to their max thermal abilities. Be safe and run lower. Maybe the DC 3.5
he said 4 not two
the subs should take the power, you just need to work on electrical
Edited by jdubs
Kenwood DDX 514
DD M3a
DD 9512G
RF 600.4
RF power series 6x8s
lots of zero ga.
Whats coming: Kenwood Excelon screen, DD high end comps, DD 4ch, XS batteries
I think that amp is fine prob perfect power for those subs
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
My mistake. Either way, his enclosure is going to play a big part.
O just as long as your not clipping :)
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
x2 yes it will
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
yes i have no exp. im going to be 18 in a couple of months. but i half assly know what im doing. dose the clipping light work good on them? because i am pissed at the audiopipe because it has blown one of my subs because of the clipping. and i know its not the amps fault its mine but i like to put the blame on the amp.
Alt:MechMan 270 Amp
Big 3: Yes
Box:6ft3 96in2 34hz
ill probably pay some one two dezine a box. what is going to be descent elet.for this set up?
Alt:MechMan 270 Amp
Big 3: Yes
Box:6ft3 96in2 34hz
  • Who's Online   0 Members, 0 Anonymous, 430 Guests (See full list)
