Amp goes into protect when car is running
Where did you ground the amp? have you checked the power wire from the battery to the amp?The only other thing I can tell you is to try and get another amp to test it and once you take that one out, without it hooked up take a piece of wire and on the disconnected amp touch the positive and negative points together.I had a problem a long time ago with a hifonics amp and took it to a shop and they did that and the amp worked fined after that.I have no clue what exactly it does but it did spark a little when he did it like it was dissipating the electricity or something.
Vehicle
2007 Chevrolet Avalanche(Co-Co)
DNX9980HD
6 Team Fi 15's(King Edition)
3 DC 9k's
8 Nendo PWX 8's
4 Custom Steg 4" Super Tweeters
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
3 DC Power 370xp Alts(Externally regulated)
21 D1600's
2 D4800's
All SMD RCA's
AudioTechnix Deadner
Viper Alarm
My YouTube- http://www.youtube.c...NG?feature=mhee
Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/
Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
It has to be the remote wire getting too hot causing it to cut in and out if ur remote is jumped from the positive terminal....that will cause the problem...run the remote behind the headunit or the fuse box....
if a wire is jumped from amp + to remote (which he did as a test), the amp should work perfectly fine. its the same exact thing as having a headunit's amp turn on lead wired up to it. amps draw a max of what, like .5 amps through the remote wire? unless his remote wire run is 30 gauge and 40 feet long, this doesnt cause the problem he's talking about.
Edited by Kranny
agreed! :good:
You said oem integrated. So how are you catching the signal out from stock deck? Rca input voltage could be a issue.. what kind of amp? Kind of car? And check power and ground connection.what is the amp powering? Subs? Highs?
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
alright i had the remote hooked up to the 12v ignition on the fuse box, so when he hit the key the amp turned on.. no prob there and i unplug the rcas and turned on the amp with the car running it still did it! and btw.. agian the amp is fine when the car is off.. its a Phoenix Gold R2.0:1 Octane R 2.0:1 amp powering a 10 inch infinity sub at 4ohms.. the amp does this with nothing hooked to it just the - and + with a jumper off the + for a remote.. still does it im thinkin the + power cable is messed up somewhere along the line
Do you have any other amp you can hook up in the car to eliminate the amp as the problem?
4 fully loaded Fi sp4 15's
2 Crescendo bc5500s
Crescendo c1100.4
6 focal mids
Vifa tweets
5 XS Power d3100's
Pioneer avh-p4200dvd
All crammed into a mustang.
http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
  • Who's Online   1 Member, 0 Anonymous, 393 Guests (See full list)
