Amp goes into protect when car is running
The power wire is hooked directly to battery terminal? Check fuse fuse holder. What size wire is it
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Do you have any other amp you can hook up in the car to eliminate the amp as the problem?
sadly no.. but before i sold him this amp i had it in my bed room hooked up to two 12" pioneers powered by a lawnmower battery of all things haha its been bangin for about 2 years no problems(: then i put it in his camaro and i get problems!??
1. Your alternator is weak, its time for an upgrade
2. if you are running a small gauge wire, then it may not be getting the sufficient amount of current.
Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow
Would a bad alternator cause it to play fine when it's OFF and cut out when it's RUNNING???.. Isn't that his issue???
depends what the voltage is when the car is on.
traxxas. have you even tried anything that i have said? you cant just ask questions then not diagnose it yourself.
hes running 13.8 soomething guys and i found out the power circuitry in the amp was bad and freaked out when it was fed 13.8 instead of just 12v from the batt so he got a new amp
  • Who's Online   0 Members, 0 Anonymous, 355 Guests (See full list)
