stroupe79 Posted November 16, 2011 Report Share Posted November 16, 2011 i was trying to find out how i should design an L-ported box for a RE 18"...I have not been able to find any info on how to design the port..i know its not recommended to do sealed enclosure(all i have had before)..but there is nothing to tell you what dimensions are needed to make it sound correct have 44" of width...24" of depth...and 14" of height to work with...which will give me roughly a 6.7 cubic foot box..(minus sub displacement) width of port opening be?..depth should it be?...length of the "L"? any help would be greatly appreciated.. http://www.stevemead...cherokee-build/ 2005 Jeep Grand Cherokee Alpine CDE-hd148bt Alpine PKG-RSE2 PRV Audio (4) 6MB200 front/rear doors PRV Audio (4) TW350Ti dash/rear doors Kicker KX350.4 Obsidian Audio (1) 18 D4 v2 revamp (2) Stereo Integrity HT 18d2DC Audio 1.2k5.25ft^3 tuned @34hz revamp Infinite Baffle Cpillar AudioTechnix 60mil deadenerKnuKonceptz & SkyHigh wire (complete setup) Link to comment Share on other sites More sharing options...
bigmescan Posted November 16, 2011 Report Share Posted November 16, 2011 What vehicle is this going in. If its a trunk car you will have to face the sub face up. If I'm reading the dimensions right. Facing up in a trunk is not a good way to go. SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74 Link to comment Share on other sites More sharing options...
stroupe79 Posted November 16, 2011 Author Report Share Posted November 16, 2011 What vehicle is this going in. If its a trunk car you will have to face the sub face up. If I'm reading the dimensions right. Facing up in a trunk is not a good way to go. its in a 2005 Grand Cherokee http://www.stevemead...cherokee-build/ 2005 Jeep Grand Cherokee Alpine CDE-hd148bt Alpine PKG-RSE2 PRV Audio (4) 6MB200 front/rear doors PRV Audio (4) TW350Ti dash/rear doors Kicker KX350.4 Obsidian Audio (1) 18 D4 v2 revamp (2) Stereo Integrity HT 18d2DC Audio 1.2k5.25ft^3 tuned @34hz revamp Infinite Baffle Cpillar AudioTechnix 60mil deadenerKnuKonceptz & SkyHigh wire (complete setup) Link to comment Share on other sites More sharing options...
412 CVX Posted November 16, 2011 Report Share Posted November 16, 2011 what kind of RE sub are you working with? you might be a little tight on space. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
Nine8SST Posted November 16, 2011 Report Share Posted November 16, 2011 Lets see a pic of that beast! 1998 SS/T Ram Build Log - Kenwood KVT-514 and KNA-G510 Navigation - 2 DC Level 3 12" - Components??? - Sundown ??? - Sundown??? - Knu Konceptz - Second Skin Dampy Pro - XS D6500 Link to comment Share on other sites More sharing options...
412 CVX Posted November 16, 2011 Report Share Posted November 16, 2011 yeah you don't have enough space to run an 18 in that space. if you could go a few inches higher, then you would be much better off Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
stroupe79 Posted November 16, 2011 Author Report Share Posted November 16, 2011 RE sxx18 Compact Optimal Sealed: N/R N/R Ported: 5.5@35Hz 8.0@34Hz *N/R: Not Recommended plan on running a BRZ1700.1d at 2ohm to power it i have got some measurements from RE audio's box calculator to get me started...i want the sub and port on the top of the box 42 wide 24 deep 14 height .75 material thickness port width 3 port length 10.25 port length(2) 3 total port length 18.5 Volume 5.864 cubic feet tuned to 35hz http://www.stevemead...cherokee-build/ 2005 Jeep Grand Cherokee Alpine CDE-hd148bt Alpine PKG-RSE2 PRV Audio (4) 6MB200 front/rear doors PRV Audio (4) TW350Ti dash/rear doors Kicker KX350.4 Obsidian Audio (1) 18 D4 v2 revamp (2) Stereo Integrity HT 18d2DC Audio 1.2k5.25ft^3 tuned @34hz revamp Infinite Baffle Cpillar AudioTechnix 60mil deadenerKnuKonceptz & SkyHigh wire (complete setup) Link to comment Share on other sites More sharing options...
412 CVX Posted November 18, 2011 Report Share Posted November 18, 2011 RE sxx18 Compact Optimal Sealed: N/R N/R Ported: 5.5@35Hz 8.0@34Hz *N/R: Not Recommended plan on running a BRZ1700.1d at 2ohm to power it i have got some measurements from RE audio's box calculator to get me started...i want the sub and port on the top of the box 42 wide 24 deep 14 height .75 material thickness port width 3 port length 10.25 port length(2) 3 total port length 18.5 Volume 5.864 cubic feet tuned to 35hz What model sub is this? the sub displacement needs to be calculated into this. either way you're gonna be dealing with a TON of flex because you don't have any bracing and only a single baffle. use torres calculator instead of RE calculator. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
stroupe79 Posted November 18, 2011 Author Report Share Posted November 18, 2011 RE sx18 displacement is .22 cubic feet thanks for pointing me toward torres calc...it was 1000x better http://www.stevemead...cherokee-build/ 2005 Jeep Grand Cherokee Alpine CDE-hd148bt Alpine PKG-RSE2 PRV Audio (4) 6MB200 front/rear doors PRV Audio (4) TW350Ti dash/rear doors Kicker KX350.4 Obsidian Audio (1) 18 D4 v2 revamp (2) Stereo Integrity HT 18d2DC Audio 1.2k5.25ft^3 tuned @34hz revamp Infinite Baffle Cpillar AudioTechnix 60mil deadenerKnuKonceptz & SkyHigh wire (complete setup) Link to comment Share on other sites More sharing options...
