Blown sub?
Even a blown sub will read something on a meter usually.... Maybe a tinsel lead snapped on it? What amp were you powering it with?
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
The only way it could read 0 would be either misuse of DMM, or the coil is open somewhere. Like said earlier, busted leads or somehow a completely separated coil(s)
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
try testing the tinsel leads closer to the cone if you can, might be a bad joint somewhere near the frame or wherever your testing from.
also you could put a 9 volt battery (one of those small flashlight/remote control ones..) across the coil terminals. If the sub moves at all you're probably measuring something wrong.
Edited by STEvil
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 312 Guests (See full list)
