DC Sound Lab
NEW Meca Park and Pound 5 world record!!
Thanks guys and we will be pushing her a little harder next run :)
And also to give you a little insight on how hard I was running it I had little to no voltage drop lol I was holding 14v throughout the entire run....
Now you tell me 4- dc 9ks @ .5ohms each lol I should see 13's or 12's and not to mention my score just bounced around the same numbers within a few tents of the starting score :)
Trust me there is more to come!
Edited by trulywickedcustoms
*2013 NEW BUILD*
12- 18" Crossfire XS v2's B pillar 4th order wall
4- Crossfire 8K mono blocks
40+ pro audio mids tweeters and horns
3- Singer alternator 400a external regulated alts
tons of audiotechnix wire
24- XS Power D1400's
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
what subs are you switching to next :D
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Well for starters I got to get a cone that will stay together I'm ripping them right outside the glue joint, so for now until I can get full potential out of my subs and warm the coils up I don't need to go to a bigger motor yet :)
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
AR cones?...
do u have m1 XLs with an added spider or 2?
Yea I have M1 XLs with the stock cone and 1 added spider now wer looking into a few different things but I'm not sure what all he's let out of the bag so I'll wait to post up what we plan to fix this problem with...
But yes I am temporarily going to the AR cones with the back sides glassed and 1 other mod to see if that holds up if not then the next option should def fix the prob just a matter of time before its out or available :)
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
When I was ripping triple joints with my xls..rusty suggested lvl 5s because of the added motor force to control the cone.. xls are maxed out at 3300 to 3700 or so watts imo..that's what I found out..on music..
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Yea we have discussed the new lvl5's as being a good option as well.... I've got 3300ish per sub so I knew I'd start running into problems :) its all good tho
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
Congrats blake !
Thanks sir! :drinks:
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
