weird voltage drop
i have a 1996 ford mustang v6. i have a brz-1700 and 2 skar 12s. my car will idle at 14.8 no matter what according to my volt meter. all the way up to about 70% volume i have no voltage drop what so ever not even by .1 volts but when i get to about 75 - 85% i drop down to high 13s but the whole car acts like its about to die. my rpms start dropping car shakes all my lights dim like crazy. i dont under stand why i have a what i believe is a entirely stock electrical. why does it act so weird?
Edited by new guy
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
cause its stock electrical.
it may idle at 14.8V, but because of the small wiring, your alternator can't push in enough power to keep it at 14.8.
i could possibly be wrong, but thats what it seems to me
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
yea i know that but what i dont get is the amp is putting out atleast 800 - 1000 rms without any kind of voltage drop but as soon as i get around 1200 rms my car starts just going crazy but i never go below like 13v i know my stock electrical cant support the full 1700 rms
Edited by new guy
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
What voltmeter are you using and where do you have it hooked up too? Check the voltage at the amp with DMM and see what the differance is when its reading the 14.8v
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
you'll never see the full 1700 with that amp anyways. Its rated at 14.4 volts, which means you'll need to constantly be charging and staying at 14.4 volts to sustain that 1700 watts, and even then you won't see it cause amps aren't 100% efficient.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
i had the same problem, til i checked at the amp and found out i was dropping to high 11's :o
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
i have a scorpion voltmeter i think and i tried straight to the batt and i tried to the radio. ill try to get a dmm and check. ill try to hook it up to my amp and see what it reads. maybe mustangs just have some kinda regulator or something to make them read incorrect.
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
im pretty sure that most all fords have a pcm controlled alt.
so unless your bypassing that your not going to use the full power of your alternator. even then on a stock electrical your alt probly does maybe 100 amps. your cars probly using 30 amps to run.. so 70 amps left for everything eles.
there goes your 700 watts.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
i got a battery for you if you need it
SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!!
2005 Subaru Impreza
My build log.
Head unit- Kenwood Excelon KDC-X695
Front doors- Rockford Fosgate 6.5" Prime components
Rear doors- Rockford Fosgate 4" Punch coaxials
Sub amp- Audiopipe AP18001d
Subs- Two American Bass TNT 10"s
Box- 2.6 cubes @ 34hz, 36in of port
Big 3 & run of Raptor 1/0 to rear powercell
TEAM 808 UPSTATE NY.
Can it be heard 2 blocks away, thats how i rate systems.
  • Who's Online   0 Members, 0 Anonymous, 312 Guests (See full list)
