Jessica Posted November 18, 2012 Report Share Posted November 18, 2012 So, i want to just cut this wall from one solid piece, it will be 12.5 X whatever. Not sure on that. What i want to know is, where the first and last cut should be on each kerf using the dimensions in the pic below. edit: the actual box is 34w X 22D I think there is enough info to figure it out, but i don't know. If you guys have a easier method that i could use just tell me. I just would like to be able to reproduce whatever you recommend into sketchup so i can check the volume when i am done. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
sprkn_ranger Posted November 18, 2012 Report Share Posted November 18, 2012 Take the circumference of the 6" diameter circle and divide that by 4 (because the 90 degree bend is 1/4th of a full circle) and then that will give you the distance between the first and last cuts. Edit- I just saw that the inside of the kerf'ed bend is a tad under 2", and that is the dimension you want to find the circumference for. And I would just round it up to 2" to make it easy on you. Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/ Link to comment Share on other sites More sharing options...
ear2ear Posted November 18, 2012 Report Share Posted November 18, 2012 The o.s. radius of the kerf is 3". The circumference of a 6" diameter circle is 18.849" Your 90 degree bend is 1/4 of a full circle 18.849 / 4 = 4.71" So your total piece is: 19" + 4.71" + 28" + 4.71" + 19" = 75.42" '09 Sierra Ext Cab - under construction (1) RF T2500-1 -running- (4) RF T1 12's (1) RF T1000-4 -running- (2) RF T1652-S Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800 Buncha OFC Knu Buncha Second Skin Kenwood DDX814 - Alpine Imprint - RF 360.3 Link to comment Share on other sites More sharing options...
sprkn_ranger Posted November 18, 2012 Report Share Posted November 18, 2012 The o.s. radius of the kerf is 3". The circumference of a 6" diameter circle is 18.849" Your 90 degree bend is 1/4 of a full circle 18.849 / 4 = 4.71" So your total piece is: 19" + 4.71" + 28" + 4.71" + 19" = 75.42" Well you want to get the circumference of the side you are going to be cutting the kerfs into, not the outside...I almost missed that as well Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/ Link to comment Share on other sites More sharing options...
Jessica Posted November 18, 2012 Author Report Share Posted November 18, 2012 So 19+3+28+3+19? I just have to get it pretty close, I mean, i've kerfed before so i know i can tweak it a bit to make it work. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
n8ball2013 Posted November 18, 2012 Report Share Posted November 18, 2012 the easiest way to pull that off is to also not try to work with the precise lenght you want. Get your kerf right and match up your radius then put your back baffle on and flush trim it with a router. That way you wont have to worry so much about being off on your calculations. AS long as you can get the radius you are after right. Takes out one more factor THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
ear2ear Posted November 18, 2012 Report Share Posted November 18, 2012 The o.s. radius of the kerf is 3". The circumference of a 6" diameter circle is 18.849" Your 90 degree bend is 1/4 of a full circle 18.849 / 4 = 4.71" So your total piece is: 19" + 4.71" + 28" + 4.71" + 19" = 75.42" Well you want to get the circumference of the side you are going to be cutting the kerfs into, not the outside...I almost missed that as well Sorry buddy, that's wrong. Think about how a kerf works. The outside stays smooth and untouched. You remove material from the inside surface so that it can collapse on itself. By what you're saying you cut the material for length of the inside radius and have to STRETCH the outside radius. That is not the case. Use the outside radius for the calculation. '09 Sierra Ext Cab - under construction (1) RF T2500-1 -running- (4) RF T1 12's (1) RF T1000-4 -running- (2) RF T1652-S Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800 Buncha OFC Knu Buncha Second Skin Kenwood DDX814 - Alpine Imprint - RF 360.3 Link to comment Share on other sites More sharing options...
Jessica Posted November 18, 2012 Author Report Share Posted November 18, 2012 I guess once i get the first cut done, the second one should explain itself once i lay the board down on the bottom sheet. I could cut the board longer than i need and trim off excess. Then like nate said, get it glued together and router the top and bottom baffles with a flush trim bit to make them match. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
ear2ear Posted November 18, 2012 Report Share Posted November 18, 2012 Exactly. I would cut the board @ 78". The most important part becomes centering the 28" portion and then cutting kerfs 4.71" either direction. Trim to length later. '09 Sierra Ext Cab - under construction (1) RF T2500-1 -running- (4) RF T1 12's (1) RF T1000-4 -running- (2) RF T1652-S Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800 Buncha OFC Knu Buncha Second Skin Kenwood DDX814 - Alpine Imprint - RF 360.3 Link to comment Share on other sites More sharing options...
Jessica Posted November 18, 2012 Author Report Share Posted November 18, 2012 ok, i think i can figure that out that way. I planned on cutting the full 8ft at 12.5 anyway. Thanks for the help everyone. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
