Jessica Posted November 19, 2012 Report Share Posted November 19, 2012 Edit: (i'm just going to recycle this thread rather than start a new one) It's been asked before, but every setup is different, so here goes. Ok, looking at my setup, I am going to just get a 50' spool of KNU cca. Run 2 runs of + front to back and upgrade my grounds, charge wire, etc. I think that should cover what I need. What do you guys think? Like i said before 180a alt is probably the best i can do, maybe a 220 if that one vendor can decide if they make it or not, lol. Read this stuff below for more info and stuff. ==-=-=-=-=-=-=-==-old post here=-=-=-=-=-=-=- Alright, I'll give a quick system rundown first. 1 skar 1500.1 @ 1ohm 1 64X4 @ 4om 1 110X2 @ 2ohm (110x2 is rated @ 2ohm) Carputer (about 15 amps tops) H/u (only using pre-outs) 5amps? Fosgate Symmery (probably 5-10 amps) + the car 2 led-acid batteries 800cca in the front and a 850cca in the back, i honestly don't know the AH on these. Ok, so that said, I am planning on getting 3 deka intimiators to replace what i have. Would a 180 amp alt be enough electrical for what I am running? ( i figure worst case scenario i would draw 300+ amps, but musically i don't see that happening. I don't drive around listening to tones and chopped and screwed stuff) Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Mrgunderson23 Posted November 19, 2012 Report Share Posted November 19, 2012 your good. i run a 4 channel mb quart and a colossus 3200 and all i have is 2 agm batteries from autozone and a stock everlast batter of a 130 amp alt 1999 Saab 9-3 TURBO Stock alt atm BIG 3 UPGRADE Everlast battery under the hood 2 Duralast Platinum H8 AGm batteries 2 Runs of 1/0 gauge front to back 250 amp Circuit breaker up front 300 amp circuit breaker on the sub amp Pioneer DEH 6500XT MB Quart ONX 4.60 Kenwood KFC components all around 2011 Hifonics Colossus 3200 2 D2 SSA icon 18s 14 volts all day long Link to comment Share on other sites More sharing options...
Mrgunderson23 Posted November 19, 2012 Report Share Posted November 19, 2012 it shoulda stay above 12.5 1999 Saab 9-3 TURBO Stock alt atm BIG 3 UPGRADE Everlast battery under the hood 2 Duralast Platinum H8 AGm batteries 2 Runs of 1/0 gauge front to back 250 amp Circuit breaker up front 300 amp circuit breaker on the sub amp Pioneer DEH 6500XT MB Quart ONX 4.60 Kenwood KFC components all around 2011 Hifonics Colossus 3200 2 D2 SSA icon 18s 14 volts all day long Link to comment Share on other sites More sharing options...
Omega5002 Posted November 19, 2012 Report Share Posted November 19, 2012 180 amp alt should be fine for what you're running, and replacing all those lead acids with Deka's will be a big plus as well. A voltmeter would be useful as well to make sure your voltage is holding up well if you don't have one already. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick) Link to comment Share on other sites More sharing options...
Jessica Posted November 19, 2012 Author Report Share Posted November 19, 2012 I do have a volt meter, it's pretty fast as far as volt meters go. Going to try to nab a VM-1 when they come out. I could get a 220, but i have two different emails from that vendor. One saying they don't make an alt for my car, and one with quotes for two different alts. The 220 really isnt in the budget anyway and it's $0.25 / amp more expensive anyway. I have to be realistic here and keep the budget down so i am going with the 180. Thanks for the replies! Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Jessica Posted November 21, 2012 Author Report Share Posted November 21, 2012 Change topic title, new question. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
AMI CUSTOMS Posted November 21, 2012 Report Share Posted November 21, 2012 CCA 1/0 ??? if so that will work for what you want to run, I couldn't see you pulling more then 250 amps full tilt everything on. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty Link to comment Share on other sites More sharing options...
Jessica Posted November 21, 2012 Author Report Share Posted November 21, 2012 CCA 1/0 ??? if so that will work for what you want to run, I couldn't see you pulling more then 250 amps full tilt everything on. yeah, 1/0. I forgot to put that. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
