cris2216 Posted February 9, 2013 Report Share Posted February 9, 2013 I have a 2010 volkswagon jetta/GLi and it has a 3 way system upfront and a 2 way component set in the back. I was thinking of buying the precision power 3 way component speakers but are these good? http://www.woofersetc.com/p-9224-pc365c-precision-power-65-power-class-series-3-way-component-system.aspx my budget for everything including amp, speakers and wires and a processor would be around $1600 which is low for sq but im trying to make the sound as clear as possible. Im also going to use the factory navigation it has. just give me pointers so i can start buying the stuff. Link to comment Share on other sites More sharing options...
bcbrassard Posted February 9, 2013 Report Share Posted February 9, 2013 Well the speakers look sweet, What kind of HU you plan on running, how many amps, crossovers or EQs? 1600 is pretty low, maybe get your front stage done first and save the rear for last if at all. Most SQ systems dont run rear fill but thats prefference in my opinion. but dont be affraid to build it in stages especaily with sound deadener, runing new wires and making sure your electrical is up to snuff for your system. Link to comment Share on other sites More sharing options...
cris2216 Posted February 9, 2013 Author Report Share Posted February 9, 2013 Im going to be running my stock headunit for now but im looking for a good processor but not kill my wallet Link to comment Share on other sites More sharing options...
White Lightning Posted February 11, 2013 Report Share Posted February 11, 2013 I'm thinking you will need something like a Audio Control device (to convert your outputs to RCAs and perhaps set up an RCA output for your subs) to go in between your head unit and your input to your amplifiers ... If you insist on using your factory headunit ... I'm not sure what you think a "processor" is going to do to help with your system. Well ... With that budget anyways Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch Link to comment Share on other sites More sharing options...
Kenyel Dotts Posted March 22, 2013 Report Share Posted March 22, 2013 Try the audio control LC2I this should help with your set up King dingalingIts not finished till i say so Bit@^! Link to comment Share on other sites More sharing options...
Watch the bass Posted March 24, 2013 Report Share Posted March 24, 2013 I'm thinking you will need something like a Audio Control device (to convert your outputs to RCAs and perhaps set up an RCA output for your subs) to go in between your head unit and your input to your amplifiers ... If you insist on using your factory headunit ... I'm not sure what you think a "processor" is going to do to help with your system. Well ... With that budget anyways Yes for what the processor, would be only usefull if you want to run active. Nice SQ amp for your setup would be one of those http://www.ebay.com/itm/NEW-SOUNDSTREAM-REFERENCE-REF4-760-4-CHANNEL-680-WATTS-RMS-AMPLIFIER-/150864743246?pt=Car_Audio_Video&hash=item23203d4b4e&vxp=mtr as compsystem a nice Morel http://www.ebay.com/itm/Morel-VIRTUS-603-6-1-2-3-WAY-VIRTUS-SERIES-CAR-COMPONENT-SPEAKER-SYSTEM-NEW-/360569708692?pt=Car_Speakers&hash=item53f3a12094, for the rear you need nothing to fancy. Good SQ comes from the front so a midclass 6.5 comp set and the gain´s low on your amp, would be fine. "in the abundance of water, the fool is thirsty" Bob Marley Link to comment Share on other sites More sharing options...
