Joe X Posted April 1, 2013 Report Share Posted April 1, 2013 400watts? http://www.crutchfield.com/S-ApXfz6Gq7s1/p_500MRPM450/Alpine-MRP-M450.html Since rms is 200 and peak is 800, I assumed anything in between was fine if I didnt leave it on for a while. I dont think the wattage specs are right, if anything Id say its double what its listed at. I can run 1 amp, save the other for the zuke. I tried plywood, mdf sounds better. No man RMS is the bottom line of what the sub will withstand for daily use safely, you can go ahead to abuse them a little but not every sub will take double their RMS rating dialy. Link to comment Share on other sites More sharing options...
john253a Posted April 1, 2013 Report Share Posted April 1, 2013 Your subs are single 4 ohm In parallel your amp will see 2ohm 2ohm load on is 400rms so 200 a piece Witch is there rate rms You could run 2 amp both at 4 ohm Giving you 200 a piece Just it's harder to tune and not alway recommend unless separate boxes But on your case stick with 1 amp and keep other for spare Link to comment Share on other sites More sharing options...
Cobb Posted April 4, 2013 Author Report Share Posted April 4, 2013 Thanks you again John for your help. Ive had a few projects and the on going job search get in the way. Luckily I had this on the printer and had grabbed it with some other papers on my way to an interview today. The person asked about my hobbies and I noticed this in my binder, pulled it out and used it as part of our conversation. He too was into audio and thought you just slap some subs in a box and BOOM you got a system. 2010 Honda Insight Eco Modded + PHEV 1995 Suzuki Sidekick 4wd 5 speed LJX Link to comment Share on other sites More sharing options...
