juan-lightning Posted April 21, 2013 Report Share Posted April 21, 2013 The sub won't fit in the slot port box unless you add a spacer for the sub. You would only have 6.25" mounting depth and if the vvx2's are anything like the vvx1's dimensionally they have around 6.5" mounting depth and a vented pole that needs to breathe. The round port design looks good, but the ports are long and won't fit. I would try using a single 4". I used to have and RE SX in a 1.25cuft box with a single 4" port tuned to 33 and it got down. Right now I have the 2 skar 10s on 2.5cuft tuned to 34 with 2 4" ports and sounds great. '02 SVT Lightning Pioneer 3200dvd C&D 80ah under hood, 2 shuriken bt20's in cab PPI BlackIce 800.4, Rockford T1 6.5comps, kicker KS 5.25comps(Running both active) AQ 2200d, 2 Skar VVX-10s, 2.5@34hz, Epicenter Link to comment Share on other sites More sharing options...
Krakin Posted April 21, 2013 Author Report Share Posted April 21, 2013 Okay I'll keep messing around with designs, I was worried about mounting depth but couldn't find any dimensions for it. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener. Link to comment Share on other sites More sharing options...
CleanSierra Posted April 21, 2013 Report Share Posted April 21, 2013 The 12 is 6.5" Same motor, probably a more shallow basket, so I'd guess 6" Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
Krakin Posted April 21, 2013 Author Report Share Posted April 21, 2013 I'll just check it on Wednesday when the sub gets here. Also it looks as if I will either have to do ports firing up and have a port bend that way, or have the ports bend inside the box to be able to fit. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener. Link to comment Share on other sites More sharing options...
CleanSierra Posted April 21, 2013 Report Share Posted April 21, 2013 So the box to driver side and port external passenger side Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
Krakin Posted April 21, 2013 Author Report Share Posted April 21, 2013 Yes, but as of now no externals. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener. Link to comment Share on other sites More sharing options...
Krakin Posted April 21, 2013 Author Report Share Posted April 21, 2013 After I start getting more of these variables worked out I'll start making CAD designs. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener. Link to comment Share on other sites More sharing options...
CleanSierra Posted April 21, 2013 Report Share Posted April 21, 2013 if you utilize the space below that rear bump, down near the floor, you have TONS of depth. With 7" top depth and 10" bottom depth, you have plenty of depth for that sub, I can assure you. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
Krakin Posted April 21, 2013 Author Report Share Posted April 21, 2013 Oh I know I have the room to put it in. And that bump is where I got the original depth from the first post. This is just the first step of my build. Have a plan on doing something similar to what the December System of the Month did with 2 SA-10s. Almost certainly going to ditch the third seat over summer. As a side note we have an amazing sail boat that I'm going to try and fix up too, it's just sat for many many years so I'll have to do some repairs on it but everything so far looks great. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener. Link to comment Share on other sites More sharing options...
juan-lightning Posted April 22, 2013 Report Share Posted April 22, 2013 Port out the side and use an elbow, should work fine. I did a box like that for a vvx1 for a buddy and sounded good. When I measured the 4" elbow it was about 8.5-9" long down the center. Post up when you get the designs going, love seeing single cab builds lol I'm gonna try stuffing a pair of 12s in my truck soon to see how much difference the cone area makes. '02 SVT Lightning Pioneer 3200dvd C&D 80ah under hood, 2 shuriken bt20's in cab PPI BlackIce 800.4, Rockford T1 6.5comps, kicker KS 5.25comps(Running both active) AQ 2200d, 2 Skar VVX-10s, 2.5@34hz, Epicenter Link to comment Share on other sites More sharing options...
