HunterJohnson Posted June 16, 2013 Report Share Posted June 16, 2013 My question concerns crimping lugs. If correctly crimped how big of a difference in conductivity is it to use a Compression Lug VS. Normal Copper Lug Thanks Fellas Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
CleanSierra Posted June 16, 2013 Report Share Posted June 16, 2013 <<<Waits for Snafu to come in and answer your question with a riddle... I kid, I kid I would guess compression during since it basically fuses the stands into a solid piece and I would assume you're getting MAX surface area out of the strands that way. I'm subbed for a good explanation though. P.S. This is the internet, we're ALL experts Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
snafu Posted June 17, 2013 Report Share Posted June 17, 2013 A riddle, huh . . . I have a fairly good explanation of that here: http://www.ceautoelectricsupply.com/big3kits.html See the Heading The Best Parts . . . Incidentally, the eyelet pictured at the top of post 1 is really not designed for automotive use. Rather, the shape of that is designed to be used in commercial electrical panels. In automotive use, it's generally preferred to have a round edge on the end of the eyelet for clearance and / or to allow the use of an insulating boot. Tony Candela - SMD Sales & Marketing Email me at [email protected] to learn about becoming an SMD Partner! Link to comment Share on other sites More sharing options...
HunterJohnson Posted June 17, 2013 Author Report Share Posted June 17, 2013 Thanks for the info, so main difference between the lugs is one is compression are longer to accept the crimp also different materials. Thanks tony Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
