reedal Posted December 1, 2014 Report Share Posted December 1, 2014 I say change your battery to a new one and try it SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
YukonDCXL Posted December 1, 2014 Author Report Share Posted December 1, 2014 Are you running anything like an LOC or a ground loop isolator? Nothing like that. I say change your battery to a new one and try it Ill give that a try Link to comment Share on other sites More sharing options...
alaskanzx5 Posted December 2, 2014 Report Share Posted December 2, 2014 Yeah read the directions again. If your measuring from the amp the subs are connected to that can create issues as in the directions I says not to. Not sure what issues it could create. Don't remember what freq track 1 is. Think its a 1k hz? t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
YukonDCXL Posted December 2, 2014 Author Report Share Posted December 2, 2014 Yeah read the directions again. If your measuring from the amp the subs are connected to that can create issues as in the directions I says not to. Not sure what issues it could create. Don't remember what freq track 1 is. Think its a 1k hz? The instruction only say to do that when setting the amps gains, but I will give it a shot. Track 1 is the 40hz track Link to comment Share on other sites More sharing options...
alaskanzx5 Posted December 3, 2014 Report Share Posted December 3, 2014 If your reading through the amp the speakers movement will still create changes. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
islandpride684 Posted December 3, 2014 Report Share Posted December 3, 2014 I am trying to tune my friends system with my dd1 but I can not get it to show signal when measuring the decks output? I have done everything I am supposed to as far as setting decks eq's to flat and lpf all the way up on amp... any suggestions? Try measuring it at the head unit itself and not through the amp... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
