YukonDCXL Posted December 29, 2014 Report Share Posted December 29, 2014 If I use the lpf (set to 80hz) on my hu for bass amp then where should I have the lpf set on my amp? all the way down? I want to use my hu for this because I do not have a cc1 to properly set at the amp Link to comment Share on other sites More sharing options...
Tarball Posted December 29, 2014 Report Share Posted December 29, 2014 Turn your amp lpf all the way up (highest frequency). CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
Ahmed Johnson Posted December 29, 2014 Report Share Posted December 29, 2014 Turn your amp lpf all the way up (highest frequency). Why Link to comment Share on other sites More sharing options...
EP95 Posted December 29, 2014 Report Share Posted December 29, 2014 if you got it set up on your headunit there's no need to set it on the amp too, just set it to around 80 or off if you can Link to comment Share on other sites More sharing options...
YukonDCXL Posted December 29, 2014 Author Report Share Posted December 29, 2014 Turn your amp lpf all the way up (highest frequency). Okay so all the way up on amp and then I can control with HU? Youre positive? Link to comment Share on other sites More sharing options...
will77530 Posted December 29, 2014 Report Share Posted December 29, 2014 no point in using to of the same filter so set it on the headunit and turn it off or all the way up on the amp Link to comment Share on other sites More sharing options...
Kyblack76 Posted December 29, 2014 Report Share Posted December 29, 2014 no point in using to of the same filter so set it on the headunit and turn it off or all the way up on the amp Correct. All the way up to me is preferred. Remember, you'll be adding the slope of the amp if you can't go to "full pass" So your hu slope and your amp slope is combined. I like ALL PASS or up full. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
YukonDCXL Posted December 29, 2014 Author Report Share Posted December 29, 2014 Thanks. There is know off so ill turn it all the way up Link to comment Share on other sites More sharing options...
YukonDCXL Posted December 29, 2014 Author Report Share Posted December 29, 2014 computer went nuts! dbl post Link to comment Share on other sites More sharing options...
YukonDCXL Posted December 29, 2014 Author Report Share Posted December 29, 2014 Shit trpl post wtf Link to comment Share on other sites More sharing options...
