YukonDCXL Posted April 22, 2015 Report Share Posted April 22, 2015 On my stereo I do not have the option to turn the lpf off so I turned it all the way up and then tuned lpf on the amp using the cc1... is this the correct way? Link to comment Share on other sites More sharing options...
Jhunt94 Posted April 22, 2015 Report Share Posted April 22, 2015 yeah. you can use either one. Using the lpf on the amp (to me) is better because, if you disconnect your batt then there goes all of the settings on the hu, so you wouldn't have to worry if you use the one on the amp. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter Link to comment Share on other sites More sharing options...
YukonDCXL Posted April 22, 2015 Author Report Share Posted April 22, 2015 I here ya, but did I tune my amp the proper way by having the deck on its highest setting or does it not matter where the deck is set when you do this? Link to comment Share on other sites More sharing options...
Kyblack76 Posted April 22, 2015 Report Share Posted April 22, 2015 your deck does not have a full pass on the sub out????? damn.. welcome to 2002 edit, if your using both the deck cut off and the amp, then combine BOTH slopes... if they are both sloped at 12db, youll be at 24db per octive. Keep that in mind SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Jhunt94 Posted April 22, 2015 Report Share Posted April 22, 2015 there is a light one the CC-1 that will turn red when the level is too high, if you see red then back it down until it's green or blue (I can't remember). If you had your volume all the way up and never saw that then you should be good. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter Link to comment Share on other sites More sharing options...
YukonDCXL Posted April 22, 2015 Author Report Share Posted April 22, 2015 your deck does not have a full pass on the sub out????? damn.. welcome to 2002 edit, if your using both the deck cut off and the amp, then combine BOTH slopes... if they are both sloped at 12db, youll be at 24db per octive. Keep that in mind This is over my head. I just turned the deck to 125hz and then tuned the amp the way the direction say. I got it calibrated so I am guessing the cc1 read 80hz... am I good? Link to comment Share on other sites More sharing options...
Jhunt94 Posted April 23, 2015 Report Share Posted April 23, 2015 http://www.nzicemag.co.nz/mobile/forum/viewthread/page/2/m/25460005/id/20593304-combining-crossover-slopes this may help explain what Kyle is talking about. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter Link to comment Share on other sites More sharing options...
