bman8891 Posted November 30, 2015 Report Share Posted November 30, 2015 I just pulled out my 2512's at 1 ohm nominal and dropped in 2 xl12's at .5 ohm nominal on a saz 3500d. I assumed since I would be drawing more power I would see more voltage drop but surprisingly its just the opposite. With the dd's I went from 14.1 - 12.0 and with the new subs its 14.1- 13.1. Stock alt 2 d6500's. Any ideas why this is? Will it drop more once the subs break in? Maybe I was hardcore clipping with the dd's? Link to comment Share on other sites More sharing options...
_paralyzed_ Posted November 30, 2015 Report Share Posted November 30, 2015 They're different subs. You have a different outcome because something is different. It's not an apples to apples comparison.Obviously the 2512's at 1 ohm are a greater load than xl12's at .5 ohm.Clipping like hell could cause he greater load too like you mentioned, but it isn't likely the subs would have survived that. Link to comment Share on other sites More sharing options...
_paralyzed_ Posted November 30, 2015 Report Share Posted November 30, 2015 A different song could cause a different load...Unless all variables are identical it's hard to compare 2 things. Link to comment Share on other sites More sharing options...
bman8891 Posted November 30, 2015 Author Report Share Posted November 30, 2015 Same songs and I suppose you're right its apples to oranges with subs I was just surprised by the dc's. They get louder with using less voltage. Link to comment Share on other sites More sharing options...
