jessdabest77 Posted February 12, 2016 Report Share Posted February 12, 2016 Does anyone the the sub cutout size for a 15" Addictive Audio version 4? Trying to look it up but no look and maybe what size box and tunning this sub's like's? Link to comment Share on other sites More sharing options...
3vil Posted February 12, 2016 Report Share Posted February 12, 2016 I'd email Addictive's customer service and try get get your answers straight from their makers mouth. Link to comment Share on other sites More sharing options...
jessdabest77 Posted February 12, 2016 Author Report Share Posted February 12, 2016 Ya I know I was just hoping someone knew cause ave to have box done by tomorrow noon. Link to comment Share on other sites More sharing options...
Hugh G. Rection Posted February 13, 2016 Report Share Posted February 13, 2016 The cutout is easy to figure out, just put a strip of wood on each side of the sub, and when you have the same measurement on both sides between the sticks you have what you need. Or if you have a big carpenters square, set it to the sub, look at where it makes contact with the sub, and multiply that measurement by two. As for the rest of the post, are you trying to compare a design you already have or are you fishing for a free design? Owner of BigAss Ports Link to comment Share on other sites More sharing options...
CleanSierra Posted February 13, 2016 Report Share Posted February 13, 2016 Quick trick that I just learned recently too Hugh, which I'm sure doesn't work in EVERY case but it's worked out on all I've tested on is this: Measure the surround across the diameter. Edge to edge should be nearly exact to what your cutout should be. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
