I am selling my RD Audio 1750.1d This is a beast of an amp and it in excellent condition. I wish I didn’t have to sell it. Looking to get $350.00 shipped, I will take pay pal check or money order. Amp ships when money clears.
Features
• Digital class-D linkable mono block amplifier
• MOSFET PWM power supply
• Daisy-chain through output RCA
• Double sided through hole epoxy PCB
• Stable into 1 ohm and 2 ohm parallel amplifier connection availability
• 24dB/oct variable crossover
• Variable subsonic filter
• Variable bass boost
• Variable low pass filter
• Variable phase shift
• Efficiency : 86% @ 4 ohm, at 100Hz
• Multi-way protection circuitry (Thermal/over current/speaker short/speaker dc protection)
• RCA line input
• Tested voltage & THD : 14.4V & less than 1% THD
• Operating voltage : DC 10V~16V power input
• Wired remote controller
MSRP
$799.00
Specifications
RMS power, 2 ohm linkable/dual mono 2900w x 1ch
RMS power, 1 ohm mono 1750w x 1ch
RMS power, 2 ohm mono 860w x 1ch
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm <0.1%
Efficiency @ 4 ohm 86%
Fuse rating 40A x 4
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 222(W) x 52(H) x 430(L)mm
n2caraudio.com
This topic is now closed to further replies.
  • Who's Online   1 Member, 0 Anonymous, 327 Guests (See full list)
