LLP Posted Thursday at 03:57 PM Report Share Posted Thursday at 03:57 PM I have a salt 8. Gains & Crossover tuned w/ DD-1 and CC-1. Once I install the OM-1, the amp starts clipping. I can then turn the gain down until it stops but the gain is almost all the way down. I have tried this several times and the amp keeps clipping early. Could I possibly have a faulty OM-1 or ??? Need to help from the Pros on this one. Quote Link to comment Share on other sites More sharing options...
crispy_chick3n Posted Thursday at 10:42 PM Report Share Posted Thursday at 10:42 PM did you set the om-1? they dont come pre tuned out of the box. there should be a potentiometer on the back to adjust when it shows clipping Quote This page is crispy_chick3n approved. © crispy_chick3n inc Link to comment Share on other sites More sharing options...
Joe X Posted Thursday at 11:59 PM Report Share Posted Thursday at 11:59 PM 8 hours ago, LLP said: I have a salt 8. Gains & Crossover tuned w/ DD-1 and CC-1. Once I install the OM-1, the amp starts clipping. I can then turn the gain down until it stops but the gain is almost all the way down. I have tried this several times and the amp keeps clipping early. Could I possibly have a faulty OM-1 or ??? Need to help from the Pros on this one. You treated OM-1 manual like it wasn't there, you will need to have a mini screwdriver available for the next step. Quote Link to comment Share on other sites More sharing options...
LLP Posted Friday at 01:41 AM Author Report Share Posted Friday at 01:41 AM Thanks for the replies. I have adjusted the OM-1 meter. My highs & mids work great. When I go to set the sub amp, as soon as the OM-1 wire is connected to speaker output, the clip light on the amp lights up until the amp gain is turned almost all the way down. It does it on the positive or negative speaker connection. I have successfully set the highs & mids, which makes me believe the OM-1 on the sub amp might be faulty. I have never used these meters before and was curious if anybody else has had the same issue. Quote Link to comment Share on other sites More sharing options...
Joe X Posted Saturday at 12:59 AM Report Share Posted Saturday at 12:59 AM You could try to use the OM-1 on the mids with the sub amp or try the OM-1 on the sub with the mids amp and see if there are any differences, Quote Link to comment Share on other sites More sharing options...
