trulywickedcustoms Posted August 13, 2008 Report Share Posted August 13, 2008 (edited) ok so i just started 1 other small project my buddies truck he has a 1999 silverado.. its a crew or quad cab it only has the 3rd door... but ne ways he is wanting to keep his backseat we put a 3" lift on it so we can get a big box underneath it .... im putting 2 -12" jbl P series subs http://manuals.harman.com/JBL/CAR/Boxes%20...4rev3_27_06.pdf ----- link to the box spec. im am wondering if a vented box would sound good in there considering the box goes up and over the drive tunnel?? and if i could do the vent in the middle where it goes over and subs on each side facen your feet.... so my big ? is has any one seen or heard this... if so do you think a seald or vented would be better for his application?? sealed=1.00 cube vented=1.75 cube thanks guys ill get som specs and see if any one can help with the design Edited August 13, 2008 by trulywickedcustoms Quote *2013 NEW BUILD* 12- 18" Crossfire XS v2's B pillar 4th order wall 4- Crossfire 8K mono blocks 40+ pro audio mids tweeters and horns 3- Singer alternator 400a external regulated alts tons of audiotechnix wire 24- XS Power D1400's -TEAM XS POWER- -TEAM CROSSFIRE- -TDH- Link to comment Share on other sites More sharing options...
trulywickedcustoms Posted August 13, 2008 Author Report Share Posted August 13, 2008 come on guys i need to be able to start his box sumtime next week any suggestions??? Quote *2013 NEW BUILD* 12- 18" Crossfire XS v2's B pillar 4th order wall 4- Crossfire 8K mono blocks 40+ pro audio mids tweeters and horns 3- Singer alternator 400a external regulated alts tons of audiotechnix wire 24- XS Power D1400's -TEAM XS POWER- -TEAM CROSSFIRE- -TDH- Link to comment Share on other sites More sharing options...
quakecitystudio Posted August 13, 2008 Report Share Posted August 13, 2008 (edited) Okay I did a little reading on the sealed box and the woofer, and I think that there graphs is a little off. Why? Look here: http://www.carstereo.com/help/Articles.cfm?id=29 and read on the Qtc. They say it's best to get a Qtc of .707, which is somewhat similar to how the music was originally recorded. So I tried out this equation for a seald box based on your woofer and volume requirement: http://www.carstereo.com/help/Articles.cfm?id=30 From this: Qts .54 Vas 1.932ft cubed Fs 27hz Vb 1 ft cubed And got this: Qtc: .9246 Fc=46.23hz F3= 37.77hz Edited August 13, 2008 by quakecitystudio Quote Bass Music Producer • Photographer • Graphic Designer -------------- Deep Sector Boom... Link to comment Share on other sites More sharing options...
quakecitystudio Posted August 13, 2008 Report Share Posted August 13, 2008 (edited) In comparison I decided to try out the RE Audio RE Series 8" woofer: Qts .34 Vas .957 Fs 22.8 Vb 1 and got this: Qtc .4756 Fc 31.9hz F3 53.18hz Edited August 13, 2008 by quakecitystudio Quote Bass Music Producer • Photographer • Graphic Designer -------------- Deep Sector Boom... Link to comment Share on other sites More sharing options...
quakecitystudio Posted August 13, 2008 Report Share Posted August 13, 2008 (edited) I noticed my own flaw with Vas I was using liters and not ft cubed, and went back and corrected everything. Are you wanting a sketch of the enclosure? What would your dimensions be? L W H Depth and the curve radius over the drive axle. Edited August 13, 2008 by quakecitystudio Quote Bass Music Producer • Photographer • Graphic Designer -------------- Deep Sector Boom... Link to comment Share on other sites More sharing options...
trulywickedcustoms Posted August 13, 2008 Author Report Share Posted August 13, 2008 I noticed my own flaw with Vas I was using liters and not ft cubed, and went back and corrected everything. Are you wanting a sketch of the enclosure? What would your dimensions be? L W H Depth and the curve radius over the drive axle. thanks for helping im tryn to get him to email me the dem. b/c he wrks all week out of state..... but ill get them asap and yeah i would like a roughd sketch with demen thrown in to help ... if thats not to much trouble... thanks man Quote *2013 NEW BUILD* 12- 18" Crossfire XS v2's B pillar 4th order wall 4- Crossfire 8K mono blocks 40+ pro audio mids tweeters and horns 3- Singer alternator 400a external regulated alts tons of audiotechnix wire 24- XS Power D1400's -TEAM XS POWER- -TEAM CROSSFIRE- -TDH- Link to comment Share on other sites More sharing options...
trulywickedcustoms Posted August 13, 2008 Author Report Share Posted August 13, 2008 i think im kinda wanting somthing like this ... or sealed or with the boxes split with a port individually?? just sum thoughts Quote *2013 NEW BUILD* 12- 18" Crossfire XS v2's B pillar 4th order wall 4- Crossfire 8K mono blocks 40+ pro audio mids tweeters and horns 3- Singer alternator 400a external regulated alts tons of audiotechnix wire 24- XS Power D1400's -TEAM XS POWER- -TEAM CROSSFIRE- -TDH- Link to comment Share on other sites More sharing options...
trulywickedcustoms Posted August 14, 2008 Author Report Share Posted August 14, 2008 come on guys im supposed to start this build this weekend .. ill have demn 2night do yall even think the idea is good?? and should i do seperate boxes or even sealed?? Quote *2013 NEW BUILD* 12- 18" Crossfire XS v2's B pillar 4th order wall 4- Crossfire 8K mono blocks 40+ pro audio mids tweeters and horns 3- Singer alternator 400a external regulated alts tons of audiotechnix wire 24- XS Power D1400's -TEAM XS POWER- -TEAM CROSSFIRE- -TDH- Link to comment Share on other sites More sharing options...
JustinT Posted August 14, 2008 Report Share Posted August 14, 2008 looks good but you are definitely going to have to raise the seat up Quote "IT SOUNDS SLOW MOTION AND STUTTERING"~~~~LOL 2 15" Fi BTLs 7.5 cf box @ 33hz Sundown SAZ-3500D Powermaster S3400 & D3100 Iraggi 300a alt SecondSkin - totally dead Knu wire Link to comment Share on other sites More sharing options...
Ray Posted August 14, 2008 Report Share Posted August 14, 2008 It is an ext cab not a quad cab. Do the port out the side both woofers on the opposite side. Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
