bass_addict07 Posted April 25, 2009 Report Share Posted April 25, 2009 my friend just put his system in and today i looked at the back of the headunit to see if he did everything right and it was hott as fukk!! like i know a headunit gets hot but it was hot enough to burn you. is this normal? or is it just because it is hot out? 97 exploder xlt2 18" obsidian audio daul 2 v2s1 sundown audio saz1500d at .5 ohm2 sets of alpine type r components1 MB quart onyx 125.4alpine cda-98871 mike singer 250 amp altxs d3400 in the backall kicker wiringBIG 3singer resonance killer sound deadner throughout Link to comment Share on other sites More sharing options...
troy Posted April 25, 2009 Report Share Posted April 25, 2009 what kind is it retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs Link to comment Share on other sites More sharing options...
bass_addict07 Posted April 25, 2009 Author Report Share Posted April 25, 2009 daul yah its shitty i know lol 97 exploder xlt2 18" obsidian audio daul 2 v2s1 sundown audio saz1500d at .5 ohm2 sets of alpine type r components1 MB quart onyx 125.4alpine cda-98871 mike singer 250 amp altxs d3400 in the backall kicker wiringBIG 3singer resonance killer sound deadner throughout Link to comment Share on other sites More sharing options...
troy Posted April 25, 2009 Report Share Posted April 25, 2009 tha prolly why to tell you the truth. just watch it is all i can tell you. make sure all wires are tight and just watch it and make sure nothing is melting retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs Link to comment Share on other sites More sharing options...
Bunker Posted April 25, 2009 Report Share Posted April 25, 2009 make sure all the speakers are wired right and nothing is touching anything that It shouldn't be triple check all of the wires, check your ground, you could wire some pc fans around it to help cool it , if all else fails it might be time for a new head unit. J&T DESIGNS M5 4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR Powermasters XS POWER Dropping MaxxSonics Pioneer Link to comment Share on other sites More sharing options...
BigJohnny Posted April 26, 2009 Report Share Posted April 26, 2009 if the HU has a built in amp, then yes it will get hot. I don't know how hot is above normal, but theres probably a heatsink on the back of the HU which is where most of the heat is coming from. If you disable the built in amp (should have an option there if it has one) it should stop running so hot. Mine gets pretty hot too, I'm more worried about wires burning, but I don't think any have yet. I'm actually looking at installing a tiny ass fan to get some air movement back there. Link to comment Share on other sites More sharing options...
BanginOnABudget Posted April 26, 2009 Report Share Posted April 26, 2009 step 1, dont buy dual. ever. step 2, get a 12 volt fan (radioshack) and put it near the head unit, and quicksplice it to ur ignition wire. step 3, bump freely. any questions??? im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire. Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block.... 1990 Jeep Cherokee 2 Dr. Big-3 in 0g on Stock Alt. Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos. Pioneer 6000ub Reciever NO amps at the moment. SA-15 on 1kw coming soon. MSG Me for a free enclosure design!! Flared port kits coming soon!! Link to comment Share on other sites More sharing options...
