dwright27 Posted August 24, 2010 Report Share Posted August 24, 2010 Can't make the port bigger unless I cut the truck. And I ain't cuttin ish yet. well jeff already told you man, if you need any help let us know and you can come up or a day or so and we can get it right 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer Link to comment Share on other sites More sharing options...
rival904 Posted August 24, 2010 Author Report Share Posted August 24, 2010 I got a meter now so will shall see. 2004 Yellow F150 STX 4x4 Single Cab 2 Yellow DC Power 270SP's Alts 4(and counting) XS Power 6500's 4 DD3515s Supercharged 53cu.ft 4th order blowthrough 8 DD M1b's 6 Selenium 8's 2 Selenium ST350s 154.1 @ 41hz Legal Burp Build Log Link to comment Share on other sites More sharing options...
corona_jeff Posted August 24, 2010 Report Share Posted August 24, 2010 I know charlie was using 2.25cu sealed and 4.5port per 3515 and had right around 270sq on the port and u seen how well that worked. I think your on the right track for the sealed side. Shrinking ported is the easy part if you can get inside. Link to comment Share on other sites More sharing options...
rival904 Posted August 24, 2010 Author Report Share Posted August 24, 2010 Yea I. Can get inside it easily. 2004 Yellow F150 STX 4x4 Single Cab 2 Yellow DC Power 270SP's Alts 4(and counting) XS Power 6500's 4 DD3515s Supercharged 53cu.ft 4th order blowthrough 8 DD M1b's 6 Selenium 8's 2 Selenium ST350s 154.1 @ 41hz Legal Burp Build Log Link to comment Share on other sites More sharing options...
corona_jeff Posted August 24, 2010 Report Share Posted August 24, 2010 Yea I. Can get inside it easily. Finally sounds like you good for a 49.9br Link to comment Share on other sites More sharing options...
rival904 Posted August 25, 2010 Author Report Share Posted August 25, 2010 time will tell 2004 Yellow F150 STX 4x4 Single Cab 2 Yellow DC Power 270SP's Alts 4(and counting) XS Power 6500's 4 DD3515s Supercharged 53cu.ft 4th order blowthrough 8 DD M1b's 6 Selenium 8's 2 Selenium ST350s 154.1 @ 41hz Legal Burp Build Log Link to comment Share on other sites More sharing options...
zfrerichs Posted August 26, 2010 Report Share Posted August 26, 2010 Shrinking the ported chamber will gain you bandwith but a larger front chamber will increase efficiancy of the woofers, but shorten bandwith. If you have a meter tune with that. Tuning to octaves works but it will not yeild the best score. Roseville, CA Link to comment Share on other sites More sharing options...
rival904 Posted August 27, 2010 Author Report Share Posted August 27, 2010 So you think that both the chambers are to big? 2004 Yellow F150 STX 4x4 Single Cab 2 Yellow DC Power 270SP's Alts 4(and counting) XS Power 6500's 4 DD3515s Supercharged 53cu.ft 4th order blowthrough 8 DD M1b's 6 Selenium 8's 2 Selenium ST350s 154.1 @ 41hz Legal Burp Build Log Link to comment Share on other sites More sharing options...
rival904 Posted September 3, 2010 Author Report Share Posted September 3, 2010 thoughts? 2004 Yellow F150 STX 4x4 Single Cab 2 Yellow DC Power 270SP's Alts 4(and counting) XS Power 6500's 4 DD3515s Supercharged 53cu.ft 4th order blowthrough 8 DD M1b's 6 Selenium 8's 2 Selenium ST350s 154.1 @ 41hz Legal Burp Build Log Link to comment Share on other sites More sharing options...
corona_jeff Posted September 4, 2010 Report Share Posted September 4, 2010 Try it. Worst case its a fail and you will have to redo it. But Hell its the 3rd bandpass in there so you should be getting close on the design. Link to comment Share on other sites More sharing options...
