Pauliesnite93 Posted November 19, 2009 Report Share Posted November 19, 2009 do the people who run the aq 2200 run them at 1 ohm if so would it be ok to run a mb quart 2000.1 at 1 ohm to each 18 hdc3 copper coils. and i am petty sure this should have been in the amp section Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up Link to comment Share on other sites More sharing options...
gti'snahoe Posted November 19, 2009 Report Share Posted November 19, 2009 yes that will be fine that is pretty good match for the hdc3 for daily use and the aq2200 is 1 ohm stable so it is fine to run them at 1 and as far as any other amp the specs will tell you if it is 1 or 2 ohm stable Link to comment Share on other sites More sharing options...
LunatikGixxer Posted November 19, 2009 Report Share Posted November 19, 2009 ya i ran my hdc15 at 1 ohm on the 2200. just make sure u dont have voltage droppage and make sure it doesnt clip. 2002 Dodge durango 4.7L Autopage 2 way remote start alarm system 2 AQ 15 Aluminum coils. 1 AQ2200D (soon to be 2). 8.5 cubes tuned to 38hz. Yellow top under hood. Kinetik 1800 in rear. Big 3. (H/O Alt Soon to come) Kicker ZX200.4 Kicker 6.5 doors (blown) RF 6.5 comp set (soon to come) 1 run of Stinger 1/0 guage (soon to be 3) All of the above is all gone Currently own a 2000 Pontiac Trans Am WS6 No audio components. Link to comment Share on other sites More sharing options...
Marlo Stanfield Posted November 19, 2009 Report Share Posted November 19, 2009 As long as gains are set properly, you aren't sending a clipped signal and you aren't excessively playing at full tilt you'll be just fine running that power. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace Link to comment Share on other sites More sharing options...
Pauliesnite93 Posted November 20, 2009 Author Report Share Posted November 20, 2009 would two Deka Intimidator 9a31 and one or two runs of 0 gauge. and alt down the road for two aq hdc3 18 copper coils and two mb quart 2000.1 strapped Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up Link to comment Share on other sites More sharing options...
