cris2216 Posted December 22, 2009 Report Share Posted December 22, 2009 how can you mod an amp to produce more power. I have a crunch pzi3000.1d and i was wondering can it be modded to get more power out of it. right now it puts out 3,000 watts and 1,500 watts rms @1ohm. and how much would it cost me to do the mod to the amp.?:hairtrick: Link to comment Share on other sites More sharing options...
Guest Posted December 22, 2009 Report Share Posted December 22, 2009 if you have to ask how to do it you wont be able to in my honest opinion. plus i dont think that amp is worth modding too. the only amps ive seen modded are the older rockford fosgate 4k's and the stetsom 7kd's Link to comment Share on other sites More sharing options...
Boon Posted December 22, 2009 Report Share Posted December 22, 2009 You can re-wind the transformers for a bit more power at lower voltage. But you have to be careful not to upset the output FETs or rail caps or in some cases the rectifiers. And it's not really a mod for the weak-stomached. Also it's kinda pointless because you have to upgrade the power MOSFETs to handle the additional current, and probably the output MOSFETs and then you may have to tinker with the drive and it all gets very very messy. Not much point on a little 1500w amp anyway. 10.x volts fo' life! Link to comment Share on other sites More sharing options...
Sampsonite Posted December 22, 2009 Report Share Posted December 22, 2009 If you are still measuring the power in Peak watts, then this is definately not for you.. lulz --Sampson 816-591-6592 www.kcrimshop.com Link to comment Share on other sites More sharing options...
TheSundownFire Posted December 22, 2009 Report Share Posted December 22, 2009 You can re-wind the transformers for a bit more power at lower voltage. But you have to be careful not to upset the output FETs or rail caps or in some cases the rectifiers. And it's not really a mod for the weak-stomached. Also it's kinda pointless because you have to upgrade the power MOSFETs to handle the additional current, and probably the output MOSFETs and then you may have to tinker with the drive and it all gets very very messy.Not much point on a little 1500w amp anyway. Kinda the first thing I thought. 1999 Pontiac Sunfire Alpine CDA-9886 Sundown Audio SAZ-1000D Sundown Audio SAX-50.4 Rainbow SAC 265.25 Components Image Dynamics iD12 Optima Yellow Top SQFire FTW. Link to comment Share on other sites More sharing options...
