cris2216 Posted January 2, 2010 Report Share Posted January 2, 2010 right now i have 2 yellow top optimas in a 2003 suburban one is in the front and the other in the back. what i need help on how many runs of knukonceptz 1/0 wire runs do i do. 1 runs or 2 runs of 1/0 wire. my alt is stock and im going to use a hifonics 2610d amp which is 2600 watts rms at 1 ohm and a crunch 1800.4 for mids and highs and 1800 watts total. and how many feet do i need to do that and for the big 3 upgrade and how many fuses do i need to use. :hairtrick: Link to comment Share on other sites More sharing options...
enemyofsilence Posted January 2, 2010 Report Share Posted January 2, 2010 i have 2 runs in my car (one for + and -) and it works fine for me. usually a run is about ~18ft so 2 runs would be about 36-40ft. and depending on your engine for the big 3, you will prob need ~10ft. but go out to your car and measure out what you may need. Team Bass-Hz Link to comment Share on other sites More sharing options...
JZeFF Posted January 2, 2010 Report Share Posted January 2, 2010 This depends on a lot of things... Obviously the Quality of the wire, Check out Knukoncepts wiring, their Fleks wire is great stuff. Avoid CCA wire (copper clad Aluminum), You want OFC (oxygen free copper) with a high strand count. Knu wire is good for that. Have you already done the big three? Running that kind of power, your going to want to do it. There is plenty of good write ups on how to do it. One run seems like it would be enough considering its a Hifonics and a Crunch, but i could be wrong there. EDIT: Im retarded. i restated just about everything you asked. Pioneer x930 bt Rockford t2500 bdcp 18" nightshade v1 DC audio 175.4 RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon) 3x XS power D2700's Knukonceptz 0awg all around Link to comment Share on other sites More sharing options...
Skullz Posted January 2, 2010 Report Share Posted January 2, 2010 The hifonics requires a 250 amp fuse not including the other amp so your already over the 300 amp carrying capabilites of the 1 wire so you really should run a 2nd one for safety reasons. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
JBurt09 Posted January 2, 2010 Report Share Posted January 2, 2010 Don't expect that amp to put out 2600 watts RMS.I've put the 2010D in your exact truck and it did 1752 watts RMS at 14.0 volts with an unclipped signal. Link to comment Share on other sites More sharing options...
