cris2216 Posted January 6, 2010 Report Share Posted January 6, 2010 right now i have 2 yellowtop batteies and the big 3 and have 2 runs going to the back is this enough to run 2600 watts rms on 3 12s. the amp is a hifonics bxi 2610d. Link to comment Share on other sites More sharing options...
enemyofsilence Posted January 6, 2010 Report Share Posted January 6, 2010 are the 2 yellow tops in the back? cause it seems like enough batt power. are you still running a stock alt or is it upgraded? Team Bass-Hz Link to comment Share on other sites More sharing options...
Steph3n1 Posted January 6, 2010 Report Share Posted January 6, 2010 well 1st of all that amp only pushes about 23-2400 watts but you should be fine with those batts as long as you invest in a H/O alt 2005 Ford Ranger Reg cab Build in Progress T3 Audio T2000 12 ARC SE4000 Stinger HPM 1/0 Wire DC power 270xp Batts: 1 Redtop up front and a Stinger SPP2250 in the back Hopes to be in and around a 150....weel see my youtube channel http://www.youtube.com/user/steph3n1 Team DBs (Driven By sound) Link to comment Share on other sites More sharing options...
mbdblue Posted January 6, 2010 Report Share Posted January 6, 2010 if you just have 1 as your starting bat, and the other in the trunk, you'll probably see a nice amount of voltage drop...if they are both in the trunk you shouldnt have a problem...and like stephen said, it would be a good idea to look into a H/O alt AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco Link to comment Share on other sites More sharing options...
Colin - STAPUFT Posted January 6, 2010 Report Share Posted January 6, 2010 Yeah, you need a big alt. and like mdblue said- if the 2 are in the back it should be pretty good. For example- I have 3 1600s and one battery under the hood. Big 3 and a HO alt. I have bad problems. LOL I can't get as much output as they can do because my amperage sucks and kills the voltage. Just know that the Brutus amps play much cleaner and put out lots more power with 14.4+ volts. 12 - 12"s in the STAY PUFT 1989 Chevy Astro Build & Comment Log Un-Interrupted Build LogYouTube Channel Chevy Trailblazer 5.1 Dolby Digital DTS Install You have a beard of a mysterious sea captain. I would follow you to hell and back. Link to comment Share on other sites More sharing options...
cris2216 Posted January 6, 2010 Author Report Share Posted January 6, 2010 are the 2 yellow tops in the back? cause it seems like enough batt power. are you still running a stock alt or is it upgraded? I do have a stock alt and a batt is in front and another one in the back I might another batt or might considering buying a 220 or 250 Or 300 amp alt which one should I buy Link to comment Share on other sites More sharing options...
mbdblue Posted January 6, 2010 Report Share Posted January 6, 2010 I do have a stock alt and a batt is in front and another one in the back I might another batt or might considering buying a 220 or 250 Or 300 amp alt which one should I buy if you plan on building bigger after this, Id go as big as you can get. you cant go too big with them. but for your setup, a 220 would be fine. AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco Link to comment Share on other sites More sharing options...
J00bles Posted January 6, 2010 Report Share Posted January 6, 2010 currently, i have a 170amp alt and two batteries on mine (yellow top and kinetik 1400) and my voltage falls to 13-13.3 full tilt. i just bought another kinetik, and have plans to get more, so i can let you know how well another battery helps me. 8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee Click to see J00bles' Youtube Channel Link to comment Share on other sites More sharing options...
BulletInjection Posted January 7, 2010 Report Share Posted January 7, 2010 right now I just have a single D2700 under the hood and will have my yellow top in the back soon. My voltage still drops a lot a ton at idle but at 1500 rpm ill sit around 13.8-14.0 My build: http://www.stevemeadedesigns.com/board/ind...8920&st=100 http://www.youtube.com/Bulletinjection Link to comment Share on other sites More sharing options...
