cris2216 Posted January 14, 2010 Report Share Posted January 14, 2010 Right now I have 2 yellow top optimas one in front other in the back and I have it connected to a crutus 2610d amp and 3 12's at 1.34 ohms why does the amp go in protect because I was playing music and all of a sudden it goes in protect why does this happen Link to comment Share on other sites More sharing options...
Guest Posted January 14, 2010 Report Share Posted January 14, 2010 voltage too low, gains too high/bassboost on high, ohm load too low, overheating. Link to comment Share on other sites More sharing options...
cris2216 Posted January 14, 2010 Author Report Share Posted January 14, 2010 voltage too low, gains too high/bassboost on high, ohm load too low, overheating. but I played music for bout 30mins and it did not over heat nd might be my voltage because it drops from 14.4-8 to 11.9-12.3 volts but I'm buying a 300 amp alt do you youthink this will fix my problem Link to comment Share on other sites More sharing options...
Guest Posted January 14, 2010 Report Share Posted January 14, 2010 but I played music for bout 30mins and it did not over heat nd might be my voltage because it drops from 14.4-8 to 11.9-12.3 volts but I'm buying a 300 amp alt do you youthink this will fix my problem seems to me like thats your problem. and yes itll fix your problem most likely. Link to comment Share on other sites More sharing options...
