Pauliesnite93 Posted January 25, 2010 Report Share Posted January 25, 2010 i am building a box for two diamond audio 12 d6 and the amp is going to be a mb quarts dsc 1500.1d. 1.25 is the cubic feet what diamond says to put them in. rite now my box specs are like 3.50 ft3 at 36.69 hz but is this box to big Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up Link to comment Share on other sites More sharing options...
Sampsonite Posted January 25, 2010 Report Share Posted January 25, 2010 It would be fine, just don't go crazy with the amount of power you put to them --Sampson 816-591-6592 www.kcrimshop.com Link to comment Share on other sites More sharing options...
Pauliesnite93 Posted January 25, 2010 Author Report Share Posted January 25, 2010 the amp is a 1500.1 mb quarts. it is rated at 1500 at 1 ohm. the subs are 600 rms Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up Link to comment Share on other sites More sharing options...
