cris2216 Posted March 18, 2010 Report Share Posted March 18, 2010 Before I got my new alt I was dropping to about 11.6 volts at full tilt with 2 optimas and stock alt and the amp is a hifonics bxi2610d and I changed the alt to a 250 amp alt and my voltage still drops to 11.9 what gives? All my wiring is knukonceptz kolosses and big 3 Link to comment Share on other sites More sharing options...
Guest Posted March 18, 2010 Report Share Posted March 18, 2010 is your car on idle when you got that 11.9? if so, thats your problem. not many HO alternators can output alot of current at idle and you need to be driving for the alternator to output what it says it can. Link to comment Share on other sites More sharing options...
cris2216 Posted March 18, 2010 Author Report Share Posted March 18, 2010 is your car on idle when you got that 11.9? if so, thats your problem. not many HO alternators can output alot of current at idle and you need to be driving for the alternator to output what it says it can. yea it was in idle so I have to rev it to 2,000 rpm for 250 amps Link to comment Share on other sites More sharing options...
kmalinich Posted March 18, 2010 Report Share Posted March 18, 2010 what alt is it? i'd be curious to see what it produces at idle... Link to comment Share on other sites More sharing options...
Decaf Posted March 18, 2010 Report Share Posted March 18, 2010 yea it was in idle so I have to rev it to 2,000 rpm for 250 amps if its a 250a alt it makes 250a max more like 100-150a at idle Link to comment Share on other sites More sharing options...
kmalinich Posted March 18, 2010 Report Share Posted March 18, 2010 hmm 150a from the alt... 2 yellow tops... anyone know the AH rating on the yellow tops? and what voltage does it make... 1) in the morning 2) at idle with the system off (ideally with your HU faceplate removed and all amps off) Link to comment Share on other sites More sharing options...
Team_DC-Derrick Posted March 18, 2010 Report Share Posted March 18, 2010 do you have a DMM hooked up to the batt to know its dropping to 11.9 or is it a volt meter hooked up to the radio? I used to have a volt meter hooked up to the radio and it would drop down low as well, till i changed it and ran it through my firewall to the battery and no more issues from that The DC Integra 3 18s to 6 15 build log Team_DC-Derrick's Youtube Team DC Audio where theres a will theres a wall....... I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones Link to comment Share on other sites More sharing options...
kmalinich Posted March 18, 2010 Report Share Posted March 18, 2010 yeah, the HU power line (especially in a factory harness) isn't exactly a high-current place to draw power from.. so it would show lower than normal..even worse when coupled with the factory HU ground.. or is really obvious like lights dimming, heating and cooling fan slowing down, RPMs dropping... Link to comment Share on other sites More sharing options...
stphating Posted March 18, 2010 Report Share Posted March 18, 2010 ah rating on the yellow top is 55, i got 2 yellow top with a dc power 270xp alt an my voltage stays at 14.9 at idle on a t2500bd ROCKFORD FOSGATE OPTIMA BATTERIES KENWOOD DC POWER 270XP 2 18" MAYHEMS Link to comment Share on other sites More sharing options...
