fritosaregood Posted May 27, 2010 Report Share Posted May 27, 2010 if you're "worried" i guess you can call it, check to make sure you have all bass enhancement "features" off on your headunit/external EQ. yea, that too^^ Quote seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970 Link to comment Share on other sites More sharing options...
Guest Posted May 27, 2010 Report Share Posted May 27, 2010 as said already, your hu rca voltage determines where you need to set the gain. I cant be all the way down a still put out full rated power, i would say you need to turn the remote bass all the way off, you dont even really need to use the bass boost at all. unless however it is a remote gain knob which im not sure if aq used them, if it is, you should set the amp with it all the way up or disconnected. all of AQ amps' knobs are gain control knobs, WITH accurate clipping indicators. Quote Link to comment Share on other sites More sharing options...
Alex K Posted May 27, 2010 Author Report Share Posted May 27, 2010 all of AQ amps' knobs are gain control knobs, WITH accurate clipping indicators. Yeah I love that. It has the power light, and a clipping light. Also, on my HU, do I want to turn down SRC lvl to 0? And my bass on the EQ settings as well? I have L at +2, Mid -3, and treb +4. Bass boost is 0. What about loudness? I keep it at HIGH because it makes my components louder. Not too sure what that's doing to my sub. Quote 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something. Link to comment Share on other sites More sharing options...
Guest Posted May 27, 2010 Report Share Posted May 27, 2010 Yeah I love that. It has the power light, and a clipping light. Also, on my HU, do I want to turn down SRC lvl to 0? And my bass on the EQ settings as well? I have L at +2, Mid -3, and treb +4. Bass boost is 0. What about loudness? I keep it at HIGH because it makes my components louder. Not too sure what that's doing to my sub. yep i knew something was up when you said the gain was barely up and you reached XX volts. put the L to 0, src level to 0, and loudness to off. i guarantee you that you are clipping if you put an oscilloscope on the rcas. you probably are clipping your components also. i have never heard a system sound good with loudness on. Quote Link to comment Share on other sites More sharing options...
Alex K Posted May 27, 2010 Author Report Share Posted May 27, 2010 Makes sence. I've been running those kappas like that for a year or so now and they've tanked through it haha. But I'll reset tomorrow and post back my results. I thought something might be up and that's why I posted here. Quote 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something. Link to comment Share on other sites More sharing options...
bassl0va Posted May 27, 2010 Report Share Posted May 27, 2010 No problem, with my gain at max it doesn't clip (o-scoped). The HU puts out so little voltage because it's 20 years old! lol. Gain is the ratio of increase, so you will be fine. Quote My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build This forum has a massive boner for ridiculous electrical upgrades. Link to comment Share on other sites More sharing options...
