Alex K Posted June 21, 2010 Report Share Posted June 21, 2010 Just thought I'd make sure this is right. I have a stock eighty A alt, Aq1200, and my car idles at 14.2 volts.Considering to run my electronics in my car, it takes lets say 30 amps, and the rest (50) is for the sub. 50 x 14.2 = 710 of the 1200+ watts, IF my voltage stays up. That's not happeneing, as its probably n the low 12's. Think if I got an iraggi 180A HO alt, and a kinetik 1400 I would get a ton more power? Thanks 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something. Link to comment Share on other sites More sharing options...
hdorre Posted June 21, 2010 Report Share Posted June 21, 2010 Just thought I'd make sure this is right. I have a stock eighty A alt, Aq1200, and my car idles at 14.2 volts.Considering to run my electronics in my car, it takes lets say 30 amps, and the rest (50) is for the sub. 50 x 14.2 = 710 of the 1200+ watts, IF my voltage stays up. That's not happeneing, as its probably n the low 12's. Think if I got an iraggi 180A HO alt, and a kinetik 1400 I would get a ton more power? Thanks Whats your current battery bank like? The 180amp alt could help, depending on the bank. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread Link to comment Share on other sites More sharing options...
czman30 Posted June 21, 2010 Report Share Posted June 21, 2010 did u do the big 3 and upgrade the stock battery Introduce a no fat chicks in the whip rule. Im gonna have tech force make up a sign that says that and put it on my car lol Link to comment Share on other sites More sharing options...
Alex K Posted June 21, 2010 Author Report Share Posted June 21, 2010 Big 3 in 0 gauge is done. I have stock duralast in front, and stock 80 amp alt. my lights dim, yes. No bat bank atm 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something. Link to comment Share on other sites More sharing options...
7jezuz7 Posted June 21, 2010 Report Share Posted June 21, 2010 Big 3 in 0 gauge is done. I have stock duralast in front, and stock 80 amp alt. my lights dim, yes. No bat bank atm i cant help you much other than tell you to check all grounds to make sure they're solid if you haven't checked that. what are you running the amp at, 1 ohm? i ask this cause i plan on getting an AQ but i will more than likely run it at 4 ohms for quite some time and on stock alt and batt with just the big 3, hopefully as long as it's like that my electrical doesn't suffer much. An Audio Technix 18" Strato on a Kicker KX120.2 My Youtube Bass Vids Updates When Possible... I've bought from JBurt09, OrionStang, bcpballer64, LoudNLow931, audioman21, and CJ18 from here (as refs) Link to comment Share on other sites More sharing options...
Alex K Posted June 21, 2010 Author Report Share Posted June 21, 2010 Grounds are good. They're bolted directly to my chassis in the trunk. No sheet metal connections, straight to block. It's at 1 ohm. I noticed my headlights still dimming a tad and voltage goin down. Ima hit up iraggi 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something. Link to comment Share on other sites More sharing options...
mporettim Posted June 21, 2010 Report Share Posted June 21, 2010 Just thought I'd make sure this is right. I have a stock eighty A alt, Aq1200, and my car idles at 14.2 volts.Considering to run my electronics in my car, it takes lets say 30 amps, and the rest (50) is for the sub. 50 x 14.2 = 710 of the 1200+ watts, IF my voltage stays up. That's not happeneing, as its probably n the low 12's. Think if I got an iraggi 180A HO alt, and a kinetik 1400 I would get a ton more power? Thanks Don't forget the amp is not a 100% efficient so that 710 watts going to the amp is not all coming out. But then also the battery is helping out too Link to comment Share on other sites More sharing options...
