Alex K Posted July 13, 2010 Report Share Posted July 13, 2010 Why does like, 99.9% of all car audio equipment, (fuse holders, amps, reducers, etc) all use shitty allen wrench screws? Half the time they're either too small for any wrench in your normal set, strip too easily, and I honestly think they don't hold down that tight.. Is it some sort of "thieve" protector? I know honestly if I tighten down the wire on my amps, as tight as possible, and I pull as hard as I can, I can get that wire out. What's wrong with just a regular screw? 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something. Link to comment Share on other sites More sharing options...
Guest Posted July 13, 2010 Report Share Posted July 13, 2010 Why does like, 99.9% of all car audio equipment, (fuse holders, amps, reducers, etc) all use shitty allen wrench screws? Half the time they're either too small for any wrench in your normal set, strip too easily, and I honestly think they don't hold down that tight.. Is it some sort of "thieve" protector? I know honestly if I tighten down the wire on my amps, as tight as possible, and I pull as hard as I can, I can get that wire out. What's wrong with just a regular screw? i 100% support you on this. both my amps use allen wrenches and for the power/ground i can almost pull the wire out. and im tightening that shit down till the allen wrench flex's like a quarter inch. Link to comment Share on other sites More sharing options...
Alex K Posted July 13, 2010 Author Report Share Posted July 13, 2010 I had an amp that had screws to tighten, and I could not pull that wire out for the life of me. The threads grabbed the wire and didn't let go, unlike allen screws where they just "push" the wire down, they do nothing to grab ahold of it. 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something. Link to comment Share on other sites More sharing options...
Freshman6969 Posted July 13, 2010 Report Share Posted July 13, 2010 yeah on my 4ch one day i was driving and my music just stoped but the beat was still going to i pulled over, and the fucking power wire was out? mind you i had NO allen keys so thanks to my flat head( i have one of those things with a Phillips head, a sharp point, flat head etc and it all folds out like a allen key set thing, if you get what im saying lol) i always keep that in my car so i used that to put it back it, mind you i could get it tighter with that then a fucking Allen key which barley fits because its too small and the next one up it too big, stupid shitttt Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
jeyrapboy Posted July 13, 2010 Report Share Posted July 13, 2010 Thats why i like my rockford amp. My RF PRIME 500.1 has the reqular screws instead of allen wrenchs. Link to comment Share on other sites More sharing options...
chapo123 Posted July 20, 2010 Report Share Posted July 20, 2010 lucky you my t1000 has allen wrench things too. fucking gay. a wire always falls out AND its 0 gauge..! i tighten that shit down hard too but sigh Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604 Link to comment Share on other sites More sharing options...
evermaxx Posted July 20, 2010 Report Share Posted July 20, 2010 Just cheaper that way.. They use it becasuse its cheaper than regular screws.... Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench Link to comment Share on other sites More sharing options...
Alex K Posted July 20, 2010 Author Report Share Posted July 20, 2010 If i'm paying over $1000 bucks for a good amp, I want some damn good screws then!! 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something. Link to comment Share on other sites More sharing options...
HHR Ed Posted July 20, 2010 Report Share Posted July 20, 2010 Ive always had better experiences with allen screws. Maybe I'm doing something you guys arent. Amps I have installed that use philips would strip easier. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion Link to comment Share on other sites More sharing options...
