Pauliesnite93 Posted August 14, 2010 Report Share Posted August 14, 2010 im havin a riiy hard time gettin the glue off the baskit. how smooth dose the baskit have to be for the new glue to stick rite Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up Link to comment Share on other sites More sharing options...
dwright27 Posted August 14, 2010 Report Share Posted August 14, 2010 Get a wire brush for a drill. Problem solved. Brass works pretty well. I'd get it as clean as possible 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer Link to comment Share on other sites More sharing options...
ALPINE408 Posted August 14, 2010 Report Share Posted August 14, 2010 The best and fast way is a flap disc for a grinder sub clean in under 5 mins with that tool FYI it's the same tool major sub markes use to clean there subs sent in to recone Have you ever had your woofers blown? Link to comment Share on other sites More sharing options...
dwright27 Posted August 14, 2010 Report Share Posted August 14, 2010 Tape off the gap as well so none gets down in there 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer Link to comment Share on other sites More sharing options...
Ray Posted August 14, 2010 Report Share Posted August 14, 2010 this disc http://www.amazon.com/Roloc-Sanding-Disc-Grit-Zirconia/dp/B0036Z5P4C and this tool http://www.amazon.com/Roloc-Sanding-Disc-Grit-Zirconia/dp/B0036Z5P4C or baller ... http://www.sjdiscounttools.com/irc3102p.html 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
Pauliesnite93 Posted August 14, 2010 Author Report Share Posted August 14, 2010 as of rite now its smooth but not all the glue is gone. do i want all bare alum. around? yes i have the magnet taped off realy good. also how long do i have till the gule sets? so the actorver spray is for the spider and foam and the ca glue is for the baskit rite? Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up Link to comment Share on other sites More sharing options...
Loudcivic Posted August 14, 2010 Report Share Posted August 14, 2010 you want the old ca glue off but you dont want the basket really smooth were your gonna glue. you want it to be a little rough so the glue can bond with the metal basket good. maybe take a little eighty grit sand paper and rough it up a little bit. the accel is only for the spider and just use the ca glue by itself on the surround and dustcap. on the screws that hold the basket to the motor you should put a little over the screws and you can spray the accel on those. you dont want the screws to back out at all. thats about it and thats ho i just did my recone with what i just told you 2015 silverado crew cab nothing atm but soon... Link to comment Share on other sites More sharing options...
Pauliesnite93 Posted August 14, 2010 Author Report Share Posted August 14, 2010 uh ya i founded out why the sub screwed up it. u know where the top manget mounts to the top of the motor metel peace. well the glue must have let lose there and shifted the motor to shove the pole in the middle of the voise coil to one side. how do i fix this or have some one to fix it i am completle dumfounded. Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up Link to comment Share on other sites More sharing options...
R_Mac_1 Posted August 16, 2010 Report Share Posted August 16, 2010 Fixmyspeaker.com can re-align your motor. 2002 Pontiac Bonneville SSEi Pioneer DEH-P6000UB Alpine SPX-17REF 6.5" components (active) Sundown SAX-50.4 Sundown z15 (3 cubes @ 35 hz) Sundown SAX-1200D 2006 Buick Rainier CXL AWD V8 Stock Bose system 12" Alpine Type E in aeroported box Profile AP1000M Link to comment Share on other sites More sharing options...
