Pauliesnite93 Posted August 14, 2010 Report Share Posted August 14, 2010 what do i do the manget has shifted from the top plate. its a audio que hdc3 18. two of them where runin off a audiopipe 30001d. Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up Link to comment Share on other sites More sharing options...
big dee Posted August 15, 2010 Report Share Posted August 15, 2010 what do i do the manget has shifted from the top plate. its a audio que hdc3 18. two of them where runin off a audiopipe 30001d. send it back to be repaired. call audioque and dj will help you out. or try fixmyspeaker.com. those guys are good too. hope this helps you . did you drop it or the box? cause ive never seen or herd of that with thoses subs. ive seen cheap ones do that over time. Link to comment Share on other sites More sharing options...
Pauliesnite93 Posted August 15, 2010 Author Report Share Posted August 15, 2010 send it back to be repaired. call audioque and dj will help you out. or try fixmyspeaker.com. those guys are good too. hope this helps you . did you drop it or the box? cause ive never seen or herd of that with thoses subs. ive seen cheap ones do that over time. i have never droped it but there chips in the magnets. also it happened on a rilly hot day and was wangin on them for like 30 mins. i so pissed. this sets me back so far. Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up Link to comment Share on other sites More sharing options...
