Pauliesnite93 Posted September 9, 2010 Report Share Posted September 9, 2010 im going to run 4 infinity 680.9cs and one audiopipe ap20004. im trying to run all knukonceptz wire. im looking at the karma ss wire. what gauge should i use. 12 or 16 Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up Link to comment Share on other sites More sharing options...
neuspeedescort Posted September 9, 2010 Report Share Posted September 9, 2010 im going to run 4 infinity 680.9cs and one audiopipe ap20004. im trying to run all knukonceptz wire. im looking at the karma ss wire. what gauge should i use. 12 or 16 16 will more then likely be ok but hey if you want 12 go for it. i would if i had it kicking around. NEUMAN Link to comment Share on other sites More sharing options...
jeyrapboy Posted September 9, 2010 Report Share Posted September 9, 2010 either would work just fine IMO But i would just go for 12 personally. Link to comment Share on other sites More sharing options...
Pauliesnite93 Posted September 9, 2010 Author Report Share Posted September 9, 2010 i will probley just go with 16 . what ohm load is them speakers. Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up Link to comment Share on other sites More sharing options...
Freshman6969 Posted September 9, 2010 Report Share Posted September 9, 2010 i used 16g, my doors sound flawless, and it was "lightning audio" brand or some shit Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
michigancapri92 Posted September 9, 2010 Report Share Posted September 9, 2010 16 should be good but 12 gauge never hurts if you can fit the 12 gauge then why not. Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED Link to comment Share on other sites More sharing options...
