port area qustion.
what dose a box sound like when the port size is to big.
Whip:2004 Ford Expedition
Headuint:Pioneer AVH-P4200DVD
Alt:MechMan 270 Amp
Big 3: Yes
Rear batts:2x Kinetik HC2400
Power Wire:carolprene 0/2 welding wire
Volt Meter:X Scorpion
Front stage:Kicker KS6502
Rear stage:Polk audio 6x8s
High Amp:Boston acoustic GT-4100
Sub stage:Audio Que HDC3 18s Copper Coils D2
Low Amp:Audiopipe AP30001D
Box:6ft3 96in2 34hz
146.8 dbs @ 35hz Sealed up
Really peaky.....It will play higher frequencies as well as what the box is tuned to(most likely low...)
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
so you want to say under 16 rite.
Alt:MechMan 270 Amp
Big 3: Yes
Box:6ft3 96in2 34hz
Under 16 what?
tuned low?? depending how much port area he is talking about, the box would probably be tuned pretty high unless the port was ridiculously long to make up for the high amount of port area. which means the box itself would also have to be bigger
and by 16 he means sq inches per foot. and i say yes, i'd stay within 12-16 sq inches of port per foot unless you really know what you're doing when it comes to designing boxes
as of rite now i have 19h 37d 49w. with a 4.5t 47w 19l port. sub displacement .66. net vol is 12.5. port area is 211.5. tuning 37.03Hz. 1 inch mdf.
Alt:MechMan 270 Amp
Big 3: Yes
Box:6ft3 96in2 34hz
Thought so, just didn't know if he was asking about a specific box...
do you think it would be cool for two aq hdc3 18. powered by a audiopipe 30001d
Alt:MechMan 270 Amp
Big 3: Yes
Box:6ft3 96in2 34hz
port area will be fine, tuning is a little high for my liking, but may be ok for you however. what concerns me is the port ratio. that's going to be a pretty thin port (when considering port ratio). it's possible it may cause some port noise.
Edited by Torres
  • Who's Online   1 Member, 0 Anonymous, 415 Guests (See full list)
