trulywickedcustoms Posted January 11, 2011 Report Share Posted January 11, 2011 im getting everything together to build my box, and im wondering if 1/4" bolts are the largest i can go to mount the subs?? ill be using T nuts and bolts so if anyone has any info thatd be great... i know that 1/4" is knda standard but im just wondering if i can go larger?? thanks Quote *2013 NEW BUILD* 12- 18" Crossfire XS v2's B pillar 4th order wall 4- Crossfire 8K mono blocks 40+ pro audio mids tweeters and horns 3- Singer alternator 400a external regulated alts tons of audiotechnix wire 24- XS Power D1400's -TEAM XS POWER- -TEAM CROSSFIRE- -TDH- Link to comment Share on other sites More sharing options...
speedball1978 Posted January 11, 2011 Report Share Posted January 11, 2011 you could if you drill the holes bigger, its the only way, kinda like what meade had to do with his new SMD's when he got them in Quote Link to comment Share on other sites More sharing options...
CJ18 Posted January 11, 2011 Report Share Posted January 11, 2011 1/4" bolts should do just fine. My only advice is to make sure that your cutouts for the subs are PERFECT. I tried using t nuts and bolts to mount my SMDs and the cutout was about 1/8" too big and the T Nuts did not have enough wood to get a good hold in the wood. Quote Link to comment Share on other sites More sharing options...
AA98hoe Posted January 11, 2011 Report Share Posted January 11, 2011 I used t-nuts and 1/4 bolts with a allen head work great. like cj said the holes have to be perfect and if you can put a lil ca glue on the edges of t-nuts to hold them in. I had problems of them dropping in the box if the bolt doesnt line up just right it will push it in the box. pain in the ass if its you last sub and cant get to it Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
