trulywickedcustoms Posted January 18, 2011 Report Share Posted January 18, 2011 I just purchased a TPI 440 o scope and downloaded all 0db tracks and used the 1khz on the front and rear outs and 40hz on the sub And well needless to say I watched Steves videos and did it exactly as he did the o scope hooked up exactly the same as his and set the scope exactly like his unless there is something I need to set up on it being as it's a brand new scope?? But anways with all eq flat I can go 35 out of 35 and never get a squared signal... Is that possible? And the sub gets alittle square peak at 34 with the sub all the way up on the deck Someone wana give me a heads up or wte or just some results if you guys have ever scoped one.. Thanks guys! *2013 NEW BUILD* 12- 18" Crossfire XS v2's B pillar 4th order wall 4- Crossfire 8K mono blocks 40+ pro audio mids tweeters and horns 3- Singer alternator 400a external regulated alts tons of audiotechnix wire 24- XS Power D1400's -TEAM XS POWER- -TEAM CROSSFIRE- -TDH- Link to comment Share on other sites More sharing options...
Rebel4055 Posted January 18, 2011 Report Share Posted January 18, 2011 Yeah some HU's can be maxed out on volume with the EQ flat and be clean. There are some that you can adjust some settings and still be clean. I have a question for you since you have a oscope. Do you happen to have a Pioneer DEH-3200UB? Was wondering if you could scope it if you did. I really got to get me a oscope haha! Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/ Link to comment Share on other sites More sharing options...
trulywickedcustoms Posted January 18, 2011 Author Report Share Posted January 18, 2011 Na I finally got to of all my old decks... But if I can find one some where I def will!! but that's anthr thing I forgot to add... I went to the graphic eq and cranked all the treble and some of the mids... Kinda in a slope pattern and still no clippin on fronts or rears....??? And the sub if I turn up the 60-80 it makes the clip worse but that's it... And besides that I never turn up any of the mids or bass... But I do enjoy ear peircing treble.... Any others thoughts?? I thought for sure if I turned the treble all the way up that I'd see clipping but sti none..... I'm happy but just trying to insure that I'm doing this correctly as I dnt want to be sending dirty clipped signals to my amps.. Thanks Blake *2013 NEW BUILD* 12- 18" Crossfire XS v2's B pillar 4th order wall 4- Crossfire 8K mono blocks 40+ pro audio mids tweeters and horns 3- Singer alternator 400a external regulated alts tons of audiotechnix wire 24- XS Power D1400's -TEAM XS POWER- -TEAM CROSSFIRE- -TDH- Link to comment Share on other sites More sharing options...
trulywickedcustoms Posted January 18, 2011 Author Report Share Posted January 18, 2011 Early morning bump for some o scope help *2013 NEW BUILD* 12- 18" Crossfire XS v2's B pillar 4th order wall 4- Crossfire 8K mono blocks 40+ pro audio mids tweeters and horns 3- Singer alternator 400a external regulated alts tons of audiotechnix wire 24- XS Power D1400's -TEAM XS POWER- -TEAM CROSSFIRE- -TDH- Link to comment Share on other sites More sharing options...
